- wiring diagram for alarm
- can I use K&N to clean ingen filter?
- 98 SE rear-ended while parked!
- windshield replacement
- '97 SE - Alarm Went CRAZY!
- EGR Cleaning
- HELP! Car doesn't pass smog check. Now knock sensor went bad
- How dumb would the car be?
- mixed feelings on sprints
- R32 Headlights in a 95-99 max
- CAI/ Y-Pipe
- ILLUMINAS: Need Them Now, Cheap!
- Where Can I get a Cheap Injen Intake?
- SE-;imited owners help
- should i get an unorthodox pulley
- Paint chips all over the hood/advice?
- Polished
- Polished
- Polished
- Ecu 07-05
- transmission mount
- ECU question...
- HID Lights
- AE Headlight Mod
- another fuel injector shot!!! UGH!!!
- Knock Sensor No Good :(
- its me again with the suspension questions
- Very loud inside the car...
- what Clutch should I get Iam clueless
- Got a fake IS300 style antenna on my car *pics*
- how to replace hood strut?
- Skyline body kit owners!!!
- I finally fawking did it...
- Car Noise Question?
- Seat broke, can this be fixed?
- Cattman Performance is alive and well, but where’s Kevin Chin?
- Where can I buy an ABS wheel speed sensor?
- Temperature of engine bay
- Is it possible to add stock headlights that didn't come on a max?
- Stock Springs
- To all that have the Sarona Side and Rear kits
- signs of alternator going bad?
- engine swap
- Clunk sounds from a stop
- air bag installation.
- I want to get my manifold cleaned and polished
- Stroker cranks?
- anyone with B&M STS , tips on Install?
- Creaking on rear passenger side 99 SE Limited
- ECU Code 0101 (Camshaft position sensor) on '96 i30
- How do I program the Garage opener???
- Stripper problems
- Help aluminum solonoid valve
- behavior of rear O2 sensor...
- Air Bag Light Flashing. Need Help.
- Pic request: Stillen kitted Max w/ no spoiler...
- I wish Nissan made this color from the factory
- 96 SE- Needs Ball Joints
- opinion needed on exhaust setup
- Coolant Temp pins?
- Question about 4gen Carpet?????
- Anyway to make the Steering Wheel tighter and more responsive?..
- Emissions today - FAILED!!!
- have some lowering questions, and Anyone use energy suspension bushings?
- NEED major help...temperature needle touch te sky...
- where can i buy a starter for cheap????
- Broken fog lights
- Spiral Max
- Got Check Engine light 0407 code
- drilling upper airbox for more airflow?
- udp question***
- shock replacement...
- Found JIC FLT-A2s for $1,555!
- Catalytic convertor??
- Sprint/AGX are too harsh... would Intrax/AGX be better?
- starter ?
- starter ?
- Sunroof seal?
- Need help on dealing with extreme heat in the car
- 2002/2003 pathfinder steering wheel
- Stillen Y-Pipe
- how to wire foglights stay on with brights?
- UDP question
- Bose h/u screwing up, what are my replacement options?
- taillight tint peeling
- HELP! Squeeking noise from steering column/driver front axle
- cosmo racing intake
- ****h3****
- Anyone ever try this?
- Exhuast
- 02 sensor location
- 95 Max Steering Wheel
- nismo shortshifter
- my car wont start - is it the starter?
- what do you think of this cai?
- check engine light
- Quick how do you take the headlight off of car
- Nismo STS???
- turbonator?
- Cosmo Cold Air Intake
- need help!! my car lags at low RPM
- how to separate b.joint without dameage?
- Rate this intake kit
- Good Hiding Spots?
- Help on dash light fuse location?!?
- Need New Exhaust... Plz Help!!! No Search Option Available...
- Knock sensor location on a 99 SE
- Dome light not working, fuses ok, y?
- center console confusion!?!?
- Drilled or Slotted Rotors or BOTH??
- hid kits?
- did front brakes now one sticking
- red led lights on ebay
- Need help raising idle speed
- simple question
- '95 Analog Odometer Problems
- HELP!! Tokico Rear Install Problem!!
- Getting tint soon.. what % should I get
- Air Conditioning
- **Video** Maxima10to1 - Burn out and 180
- What all do i need to install new struts and springs
- critical decision: 97+ front convertion + stillen lip or part out and leave the org?
- Help went through 2 mass air flow sensors and think its cuz of my injen CAI!!!
- trouble with hood latch
- best prices anyone?
- Throttle Body Cleaned but air filter lower?
- pics of my S-Tech drop..
- need help quick with indiglos...
- sh!t! need urgent help. regarding CV axel install.
- is there a transmission filter?
- anyone have this idle problem
- where are correct jack stand points.
- headlight conversion
- Tinting headlights
- Weird noise when AC is on
- quick help please: torque value on the 17 & 19mm strut bolt and nut?
- Car won't start after fuel filter change
- '98 SE hard/weak starting
- KeyFob
- mil light on after cai install
- Underdrive Pulley - 1995 Maxima SE
- Autotechnic Gauges Install
- Engine code 0701 and 0304.
- best brakes for the buck
- Swish Valve Actuator
- Which indigio gauges are best?
- Shortening stock shifter
- small leak at the two small power steering tubes.
- bought a used 96 GLE, came with ugly rims, would painting help?
- Grounding Kit
- Just got a new security system
- what brake fluid do you use in your 4th gen?
- Bleeding brakes with speed bleeders...
- cat convert. / muffler~
- air write-up?????
- anyone have these 97-99 redclear tails?
- Help Me I Cant Find My Knock Sensor
- Paintless Dent Removal- you happy with the outcome?
- starter on 97 Maxima
- Dropzone Coilovers
- Break smell
- Noise from the wheel...not axle or bearing.
- Can't afford y-pipe. Can I gut the pre-cat?
- E brake cable?
- Leaking Power Steering
- Audio wiring diagrams
- Jim wolf ECU with supercharger, and mevi question
- Looking for 95-96 SERVICE Manual cheap
- relay problem, what symbol does fuel pump relay have?
- How do I stop this beep?
- 97-99 grill on a 96/Tinted Tails/Shortened Shifter **Pics**
- Repainting rims
- Cone Filter for A Stillen...
- CV axle install = failed
- Window Tint Brands...
- *need the pigeons tv comercial*
- brake pads
- Follow Up on Clutch
- Smell From Vents
- Engine Oil Question
- My Maxima never ceases to impress me
- Place Racing Template
- engine treatment...
- 20hp speed chips-whats the deal?
- noise from left rear wheel when turning right
- plannin on getting 17's or 18's....What else do i need to buy and do b4 install???
- Auto reluctant to downshift?
- Compression Numbers ??
- O2 sensor change
- Beware Race Thread, read at your own risk
- How do you get sponsered?
- M14 = M21?
- smokey exhaust.......
- Would this nitrous kit work or is it bogus?
- would resetting the ECU change exhaust sound??
- Clicks when the key is turned on
- Vote Again
- Increased Gas Mileage with mods?
- Where to order RPM Switch?
- HOW TO CLEAN AND DEGREASE A Y-PIPE before installation
- Friend suggested MIXING gas octanes. This safe??
- Attention Ciefro Owners!
- Headlight Bulb Question
- ?? happy with numbers ??
- Speaker setup .. ?
- dual exhaust???
- maxima model
- Which fuse is blown? I do nto have the little plastic thing.
- opinion: best lowering kit
- roots blown maxima?
- had tune up done no change?
- Headlights dimming
- brushed aluminum on a tan interior
- fuel injector problem or engine missing
- Comfortable lowering springs
- My 4th Gen Max is the best...
- Cant get my hub nut to break
- 98 and 99 max dif??
- oil weight question...............
- 97 Max SE Dome & Courtesy Lights
- will 2003 straight pipe fit on a 97 maxima?
- exhaust
- Cost for Knock Sensor and o2 replacement
- yet another loud muffler thread, please advise
- From Mustang to Maxima
- windshield wipers
- manual tranny question on 95 max
- Interior lighting
- Bolt on top of front strut will not tighten, blown strut??
- Oil light
- mevi installed? what is the best rpm to activate at?
- Is installing rear-rotors hard?
- ecu code 1107? What does it mean?
- light covers
- Installing indiglo gauges cant get the dash out
- Stoopid question...
- Emissions: Y-pipe/MEVI/ECU
- Y-pipe problems
- Samsung SM5
- Breaking Idler Pulley Center Nut
- Having problems
- Nokya headlight bulbs
- Teins S with 19 inch wheels
- magnaflow cata
- Consult interface connector
- Rear Heated O2 sensor
- Electrical failure while driving
- Wiring advice
- auto trans actin up
- drive in movies gas usage
