- Stock non-bose speakers
- Spindle Bearing?
- Just got hit while working on my car!
- Please Help with my Transmission Problems
- should i bother doing this??? intake warz
- does anyone know the OHMS a ignition coil is supposed to be to test if its good?
- Fed Spec YPipe on Cali Spec Max
- euro maxima (yeah, again)
- engine stalls when shifting into reverse - share your inputs
- Installed B&M Ripper STS + Momo Knob & Boot
- rear main seal leaking
- Valve body mod and/or shift kit info needed
- Tired of replacing cracked fog lamps
- 99 cali knock sensor, HELP!!!!!!!
- 97 Max won't start
- what shocks would go good with the tein-h springs?
- help on new horn sound
- Transmission Blew Up -I30 LSD Swap questions
- Had an accident, had questions.
- I need a quick part number please
- Big Problem taking off Spoiler!!!
- air/fuel gauge. which wire?
- **New Y-pipe design**
- Help Pulling the Transaxle
- fuel filter for 97 max..
- 04:13 engine trouble code
- New Guage Mod
- tein s tech, read if you have them
- cheapest place to buy B&M short shifter?
- whats wrong with my car
- need recs on an exhaust tip
- Installed Cone Filter, now car won't go past 3000 rpm
- yeah its light blue (56k maybe)
- how long did you stock clutch last
- #5 cylinder f'd up
- High Idle after TB cleaning
- so i've been doin some thinking...
- I think im screwed
- new to the thread, but not to the org
- suspension
- throwing 0304, no symptoms though...
- PICS: Paint job, type 2 wing and just hotness
- Need Help Cel Came On With Egr Solenoid Valve Or Circuit Fault
- gauge cluster lights.. cold cathode??
- Dropped the Max; take a look
- I'm going to be on my third manuel tranny!!!
- I am 2 LEDs short to complete the project...please donate!
- How do I get permission to search forums ?
- weight reduction
- good but pretty cheap CAI?
- "Euro diamond cut clear corners" anyone?
- Cylinder misfiring!
- Shift light bulb
- Fake carbon fiber trunk for $250 bux, is it worth it?
- GLE Sway Bar?
- check out my new kit
- For all you retrofit or skyline headlight moders
- Ae Mod Please Help
- failed smog, OBD pulled these codes
- First new posts since org has been down!!! I have a question!!!
- MagnaFlow Street Series Universal SS Muffler
- Hard Shifting Transmission
- Trenz Grill for 95 Maxima SE
- My tranny going?
- ECU codes, what to do?
- greater vibration in colder wheather
- Injen CAI - Wet weather driving
- LSD on any stock 4th gen??
- dilema...
- CF mevi cover?
- CODE 03-02 EGR System Hi/Low Flow HELP!
- Help car is running really rich and backfires.
- screwed!help me please!!exhaust bolts omg!!
- Best Clutch? ACT, JWT, Unorthodox. Stage 1's
- polishing intake manifold
- A/C Recharge
- anyone have the chilton's manual online?
- Woohoo! Max to be Tinted this THURS. Few ques: Can REAR defroster screw up tint?
- whats up with my ignition?
- Zagato27's Headlight cleaning pics...
- wtf...is that sound?!!?!
- Truck clipped my Max
- Aiming Headlight
- brake light in my cluster wont go off
- the bright red paint on the 97+ max's
- 97 Maxima GLE Spoiler LED's
- 2 drag racing videos
- Cold stalls, but no code thrown & moon roof prob?
- Gas mileage question
- Injen intake question
- noob question
- Y-pipe but don't feel gains
- Altezza's
- Help - Need K&N filter part # for PR CAI
- Diamond cut or black chrome?
- CEL help
- Foglight aiming piece - from diagram
- how will DROPZONE springs do i GR-2's?
- touch-up paint
- Ebay fuel pump a good buy?
- Which one should I get?
- Anybody have steering problems like this???
- My bad, Murano Wt is 22 lbs +/-2 lbs
- Help car does not start at all
- Bad timing for me!
- more cigarette lighter outlet?
- Difference between V1 and V2 supercharger
- Mevi Vac Cannister Questions
- Just successfully overhauled my a/c - report (long)
- 1999 SE is "thumping" at idle
- Moving Driver Seat Back 6"-12"
- Starter motor prolem
- DEI Cryogenic Intake System
- Some suggestions for the max
- Heated Seat Wiring Diagram or How To
- axle seals
- Power steering flush/transmission fluid
- throttle body mod
- why me? my car always has a problem
- Why max doesn't come with rear sway bar stock?
- ebay aluminum dash
- Jet Chip Upgrade and MEVI
- The Weight of The Murano Rim is 32 lbs
- headlights on the bay
- LED Taillight?
- antenna won't come out
- Oil Pressure Guage - Why?
- noise in front end
- cap questions
- Stock muffler downgrade?
- foglights not working
- is springs w/ stock struts possible?
- How low to go?
- Calling all those with sound clips/camcorders!!!
- if my coolant temp sensor was bad, what symptoms would I have? except for a code...
- exhaust sound cutout after 3K?sound
- service engine soon light
- need a good intake for cheap
- bigger caliper
- 5x115 on a 4th gen
- infamous Z mechanic is telling me my car is falling apart!! help!!
- Auto Trans Question
- wire layout for air conditioner
- weird winding sound....
- Clean Headlights at Last
- Hydrolocking
- I need a pic of the front jack point
- engline runs louder w/ the A/C on?
- another 5 spd thread
- Mevi
- brake - wobbling vibration
- Antenna...how do i make this work?
- OEM vs. Performance
- New Shoes
- Goop dripping on front driver side rim
- WarpSpeed Y pipe owners??
- y-pipe
- Chrome Gauge Rings?
- Fell into the engine...
- Best 1.5" Drop on SE Struts?
- How Much Do Rims Weigh
- Trouble w/ MEVI wiring...
- Help testing harness continuity
- Replacing wheel studs
- Damage analysis**
- My car keeps dying when I put it in neutral
- Anybody with custom paint?
- Help: Car is making noise while moving.
- Perfect Fit Bra foglight cutouts?
- head light removal Not bulb
- Radiator Flush.
- Update on VQ35 6 speed swap
- rear brake piston (not a c-clamp question)
- Need Carfax Report For Vin
- ECU Codes+ after Fix?
- Pulled the MEVI, putting on the 2000 VI.
- dummy CEL
- People who swapped to a 5spd... info plz.
- MEVI or 2000 VI
- Cd changer on bose stereo
- My car tops out at 120 why?
- Ever tried bleeding brakes with car on the floor with wheels still on?
- ranting of a fellow 4th gen owner...
- Car is dead, im at my wits end. Please help.
- Changed trunk letters to carbon fiber!
- need help removing flywheel
- changing lights in bose audio console
- TINTING: can you really tell the difference between 15% & 10%??
- pulled out interior carpet and weighed it
- Got Y-pipe installed, sounds like an old pontiac
- painted interior trim, looks good, 56k sorry
- Boost Guages
- Cutting Sprints??
- Rotor Got Jaked Up!!!
- hard starting and rpm stay abnormally high for first few min...
- HELP The AC Evaporator has a leak!!
- Replaced CV joints still sound...need suggestions
- tachometer having seizures!! why??
- I can't get my clear corners out!!! Hidden screws??
- 97 - foglights
- Added Topspeed SS axleback and other mods!
- are these BSA rims any good for me?
- tinting ALL lights in front QUESTIONS
- Auto body shop used by Koppel Nissan of Queens
- timing chain sqweel? how to fix
- Couple of ?'s for the guys that have painted their OEM center caps.
- Need help quick! for removing rear speakers
- weird noise when engine starts?????????
- 5spd conv. performance probs???
- sum1 locked me keys in teh car
- 1.5" drop vs. 2" drop
- Konig Imagines - good idea?
- Uneven tire wear in rear tires causing "wha wha wha" sound?
- Codes NEVER STOP!!
- Gaby email anyone know it??
- question about tires you are running.
- bought MAXSPEEDS recieved DROPZONE springs
- AirBags??
- some quick questions
- Difference in harneses for rear window switch 97GXE & 98SE
- Knock Sensor Code
- Check Engine Light Triggered by Trunk?
- Strange thing?
- 95 Maxima window regulator replacment
- shaky
- is there a such thing as a carbon fiber mevi cover?
- 1997 Bose System
- Alternator Part Numbers
- better suspension set up
- Xenon HID'S
- strut plate, strut plate bearings
- Maxima & Accord V6 Cruise LOTS OF PICS!!!
- Error code 0302-EGR hose had anti-freeze
- wire layout for air conditioning control
- 300ZX ECU in 4th Gen?
- Got my new 18's put on...Pics!!
- check engine light-can it just be cleared?
- Thats a Tuffy!
- Pics of DIY red/clears + slight how-to with oven
- ECU code 1447 :Does any1 know what causes it?
- I looked all over the board but didn't find an answer...
- Supers and Turbos
- Thinking about adding a tranny cooler
- Hepl needed...Fuel gauge is off..
- A/C bulb size?
- Automatic with Mevi
- A step backwards
- FrankenCAR exhaust on my 4th gen
- Meguiar's #7 Polish!
- Engine Coolant Temperature Sensor HELP
