- just paid 60 bucks to get y-pipe to cat bolts removed.
- My 99 SE 5 speed totalled, should I get a 2002 SE 6 speed?
- Thinking twice about my 00vi swap!! Plz help!!
- My car is now a bit shorter...
- Eibach Alignment Kit (Camber kit)
- Looking for the voltages
- Is it worth gonig OEM with exhaust studs, bolts etc.?
- 1999 Maxima factory alarm going off
- steering wheel shaking..
- How's your factory paint holding up?
- Need an electrical guru's help.
- Door speakers will be the end of me..
- new bearing or entire hub?
- are 18's too big? are 235's too wide of a tire?
- tapping noise
- Humming from front end
- Gas Filler Neck
- Brake & Battery light
- Asking for help in purchase decision...
- How to properly seal a Y pipe.
- Another Nissan going to Heaven.
- ugh... winters comming
- anyway to make these rims fit the max?lug pattern too small.
- Custom Strut tower Braces for sale.
- clunky shifting
- Strange brake noise
- Rocker panel rusting from the inside
- How do I apply RTV to Walker flange gskt for y-pipe?
- Need some help. CEL, shaking car
- throttle
- Difference between auto and manual tramission mount
- Weirdest problem I've ever had with my car - plz help
- will 98 gauge cluster & steering wheel work in a 95?
- What headlights are you guys using with HIDs?
- pic request.. bracket for r34 headlights
- received my WS y-pipe/magnaflow cat
- wanting to get a electric Exhaust cut out
- Does a y-pipe exhaust leak cause a CEL?
- Need a good nissan site
- Should I straight pipe my car??
- 0304, but knock sensor and subharness are OK
- What's the difference
- not advisable to use 4 jack stands simultaneously?
- brake pad question
- Need confirmation with AC bypass belt size
- Suggested addition to tool box.
- KYB/AGX's for sale
- Bumper reinforcement for a 97-99 fit a 96?
- Clicking sound when turning all the way to right
- can i change control arm bushings or only whole arm.
- would you trust someone to run your car off of hydrogen?
- any ideas???( amp overheating)
- when i rev up the coolant needle moves and miss fires.
- bad ignition coil?
- Emerg Starting Problem
- Did I get ripped off?? and is this fender easily fixable?
- Sell or Keep
- What does your max idle at?
- p1320 all new parts?
- Exhaust leak on rear downpipe... is there a way to seal it?
- Removing Splash Guard Rt Front WheelWell
- 4th gen outline decal??
- should i start getting mad at warpspeed yet?
- Knock Sensor MPG
- Preferred method of detatching drive shaft from engine durring engine swap?
- someone verify my alternator diagnosis
- How to replace parking cable?
- A/c not working help!
- Windshield Washer Pump
- replacing clock in 99 I30
- Do pending CEL codes have to be cleared manually?
- Possible bad knock sensor?
- could this guy (harness) couse p1400? see pic
- Replaced NGK plugs and car won't start!
- Coolant by firewall, headgasket?
- supercharged engine management?
- problems starting
- My new Lights!
- The Back Seat Fold Down MOD!
- At what point do you junk your Maxima?
- Help with Flywheel Question
- changed spark plugs and lost power!!
- Hawk brake pad parts number
- Is a hissing sound from around the IACV normal?
- should i be getting better mpg with new exhaust?
- Overheating.
- '97 gle rear caliper stuck/rusted
- Cheap Angle Eyes
- Alarm System Cuts Off Fuel?
- Engine Siezed? How can I tell?
- Whine coming through the speakers.. when the car is off?
- 4th Gen Stance pics Thread - No Comments Pics/Specs only!!!
- please help 98 maxima wont start with ignition just backfires" but pop start
- HELP 6spd swap
- quick question about clutch freeplay
- Suspension and Wheel Noises
- Rear beam re-alignment question
- Radiator replacement...easy DIY? Aftermarket suggestions?
- Car starts then stalls immediately, FPR?
- The Brakes Thread.
- car wont start..help
- Coolant resevoir brown, radiator coolant green but with sediment?
- whats your rpms at 85mph?
- What needs to be modified to use 3.5 headers?
- budget build
- Factory Bump Stop Pictures
- Side skirts?
- a32 cefiro parts
- coolant in egr
- miss firing after cleaning the engine.
- Front wheel hub removal
- I finally posted her...
- just bought some cheap aem fogs
- New plugs on '99 and now the damn thing hesitates!
- car audio question
- WAT DO YOU GUYS THINK!?!? 4TH GEN MAX
- hey guys.
- First Maxima Project [Edited]
- Battery light on - over charging
- cali/fed spec y pipe
- After adding grounds starting problems
- BG fuel induction and injection flush, yeah or nah?
- Thinking of obx udp
- Ksport springs
- can someone please post pics of a 97 front window motor?
- [Test] Knock Sensor OBDII Reading
- car doesnt start sometimes
- 98 Max jerks when i hit the gas then car cuts off ???
- Knock Sensor Bypass
- After reading HHO...anyone with pictures/results ?
- recap of my lower radiator support R&R
- 0512 Oxygen sensor
- wierd headlight issue
- OBD2 Problems
- Wheel Spacer Choice
- Window stickers...
- Violent jerking/bucking problem on 99 Max SE
- What color should i paint my rims
- Front and Rear stut tower braces.. Possibly willing to make and sell
- Question about little braided wire attached to cat
- reduced gas mileage 99 maxima
- Joining the fuzz....
- 0908 CEL CODE, WHICH SENSOR??
- LSD Optional on I30?
- 0115. Can over-gapped (.44) sparkplugs cause this?
- Help Me Pass CA Smog? (High nox) :(
- cooling fan issue
- anyone install racing seats?
- replacing plugs on 97 Se with 160k
- I need a "How To" for installing headers
- Ebay crankshaft position sensor REF ok?
- Hard start
- Bumper/Lip Chipps
- Will These Fit On The Max?
- Does 2001 Radiator fan assembly fit?
- Confused about my o2 sensor placement
- IACV Ticks and low idle, video included
- 95 Max
- E3 Sparkplugs?
- What Is This Hose?
- okay i just ordered a y-pipe...
- 95-96 Front bumper cover onto 97?
- Wow, oops... Electrical Nightmare.
- Nissan, Renault and Mercedes Make Major Announcment
- Crank Pulley failures - how many miles?
- car stalled in traffic.. no restart. found prob MAF
- code p1335... i already chenged CPS and it came back.
- Half way through its life?
- Help - Pulley Problem - See Pic.
- Inner tie rods
- 97 Alloy Rims???
- Auto trans O/D light intermittent
- Car revs to 1.5k then drops to 1k. TPS issue?
- Strange O2 issue
- Dash Trim???
- Alternator issues, just replaced 3 months ago and dead again?
- New 96 in the family
- Serious chassis issue
- Non-Bose facelift
- Correct Way To Flush and Fill Auto Transmission
- non-bose removal with pics
- Orange corner lens
- Failed inspection!
- Swapping 95' Heated/Leather seats into 98' with Cloth questions
- So, My (ex) maxima finally hits a Guard Rail
- just put some 20s on my max yesterday!
- do we really have 18.5 gallon gas tanks?
- power window electrical issue
- LED Bulb 17000mcd
- Need pic of 4 gen dash with key turned to on
- HELP! Need to replace front lower control arms/ball joints
- P1605 caused by Auto to 5 Speed Swap?Help?
- Where Can I Get A Good Bumper Lip???
- 5 speed swap electical modifications - How To
- Walbro Fuel Pump Noise?
- why does my 0-60 seem horrible?
- 200,000!!!! woot!!! 95 gle max
- park/neutral saftey switch on a five speed!? please help(searched hard) p1706)
- New Exhaust (sound clip)
- A/C gone?
- A/C Sounds like a intake from the inside.
- fog lights not working on 97 gle
- Where did "bad grounds" get started?
- photoshop my car please!!!
- Rebuilding my valvebody help me with the install.
- Rattle/clunk noise over small bumps
- DDM Tuning Apexcone HID
- Ebay Shocks/Struts? Yay or nay?
- What could cause fuel pump fuse to keep popping??!!
- Ready to get rid of my non bose
- How to test alternator directly
- Is there a Cowl top insulation substitute?
- Rear Defuser for my 95
- My wipers stop wipeing
- A/c help!
- Brake pedal side to side play
- Yellow plugs? How do these look to you guys?
- Got New 95 Max Few Simple Issues
- No fan on any setting
- Overheating - but "haze" in garage after...why?
- Dorman control arms
- 95 5spd Lagging
- Fuel Injector cleaners?
- Thoughts on Buying Used Suspension?
- changed my steering rack...
- A/C Strength Varies..
- code P0450 cost?
- Is there a e85 conversion for our 3.0s?
- Exhaust question... 5th gens?
- Airbag light on a '98
- this valve object clicks when battery is connected
- Ridiculously long list of WTF do I do now?!
- sunroof wont close.
- Low cost sound deadening.
- GFORCE Performance chip
- Any oe ground wires on valve cover?
- Sunroof weather stripping
- where is the bank 1 sensor 2? pls see my pictures
- 1999 I30 Not starting, video included. FPR changed
- wats up guys im a newbie here!
- ac vent question..
- "whining" noice when around 70 miles
- Could it be a Tranny Problem.....?!?
- Map/Baro Solenoid Air/Vacuum Sources?
- Fuel Pressure regulator has a rubber washer?
- Caliper guide pins front vs rear - bushing or no bushing
- Sporatic quitting/starting
- Turn Signal Removal
- Does the bottom half of evaporator canister come off??
- i have bee's!
