- Fix one thing and find another (electrical)
- Price of Automatic Tranny Solenoid?
- Help, signal lights blink too fast
- Got a keyless entry remote "?"
- ball joints HELP??!!!?!!!?!?!?!?!
- Springs
- How to install sidemarkers like this? *pic*
- Anyone here have a red lighted interior Max?
- Some needed help, and some track action
- Got fu#$% pulled over, s%^t!!!!!!!!!!
- Bose amp location?
- Steering wheel size?
- "Angel Eyes" are on the Bi-Xenons...[PICS]
- TV Antennas
- Whats the deal with JWT/MEVI?
- Changing Knock Sensor (need help)
- Window Track Lubrication
- Looking for DIY Shock/Strut Replacement on 98 Maxima
- lower arm bar sale
- Paint Question
- What size bulb?
- 300Z brake calipers swap-in
- obx catback exhaust (ex9758r)
- Where does the power trunk switch go?
- What's are the disadvantages and advantages of UDP?
- I just spent 3+ hours making an awsome write up for replacing leds in switches Look!
- Body kit question
- Manual Tranny fluid question-need answer asap please!
- straight exhaust kit
- Major problem...
- where can i find this engine part?
- muffler idea....altima variable
- clutch
- 91 oct from sunoco or 93 oct from anywhere eles?
- Does anyone want a very good write up on installing LED's in switches?
- What Mod did you ask Santa For?
- Delurk, first post - THANKS YA'LL!
- fog lights
- Please Can't Search,so Whats Wrong When Hi-beam Work N Lows Don't Help
- Where to find authentic K&N filter for the Max?
- Is it my clutch...clutch chatter with a stocker.
- Wife is having a girls day off....things to do to my car? Instructions please
- Those of you on Maxspeeds, did it lower your car enough?
- For anyone with the custommaxima.com rear dual exhaust bumper
- painting the dash?
- O/D off or on??
- CEL turned off on it own
- how do you do the 1 touch sunrooh mod?
- Fstb
- Fuel filter part # question
- Veilside 100mm Throtle Body
- 5 speed pilot bushing problem
- What sound does your ABS make?
- feels like flat..but isn't
- KOBA bulbs off of Ebay
- any1 have instructions on how to add abs
- Locking lug nuts
- Clock is dead
- Has Anyone swapped parts from 350Z??
- Quick Q's Need Answer!~
- Whats wrong with my cars steering,suspension
- What spark plugs do you guys use
- Are R/T cat claims true??
- How Many Of Us In Here??
- More power
- Poll: How Many Of Us In Here???
- 95 GXE 5 spd 174,000
- How do you get the vents back in?
- Car must be on to hook up spoiler - why?
- Removing Polyurethane
- O2 Sensors
- Hitachi (sp?) Boost Sensor
- cruise control not working...
- Hesitation under Acceleration
- power steering problem HELP
- code 0705 evap control unit
- Brake Pads and Muffler?
- Magnaflow can make us a full catback.....if...........
- Anyone know of a good wood 5 speed knob and ebrake
- catalytic converts
- What happened to the vqpower website?
- headlights and taillights
- help...car won't start
- Creaking noise....
- Weird thing I saw today
- Injectors problem ? 95 Max 80K
- High mileage tune-up
- B pipe ?? for 99 cali spec
- 1998 SE Fog Light Question
- cheap, quiet replacement for stock muffler?
- Speed Sensor prob-Code 0104??? HELP!
- i break everything i touch. this time, my window switch is broken.
- rust, exhaust parts falling off, etc. need a little help.
- Squeeling belts HELP!
- Technosquare or JWT ???
- Warped rotor- Fixable or no?
- Just changed my knock sensor...and i don't really feel that big of a difference..
- Post pics of your Maxima with Body Kit !
- exhuast rear section question
- Removing Intake Manifold - NEED Help!!
- Lookin' for a pic
- Question about popping suspension
- Need to find piece of interior trim
- Winter brings out the worst in cars
- underdrive pulley help install in GA
- b-pipe....different or the same....
- 97-99 rear O2 sensor...
- Carfax Needed Please
- ks code month after replacing ks
- Maxima: Gave me a 600-700 bill for xmas
- B-pipe support bracket..
- IACV how-to???
- Clunky Brakes
- Exhaust pipe bracket
- 02 and Knock Sensor
- For those with UR UDP
- HELP!! Fogs not working
- erasors in engine mounts...
- How the hell can I actually do this? HELP!
- Projectors are out of the car...
- Any of you have pics of your car lowered with Sprint springs?
- Rhythmic knock after oil change
- alternator failure
- About Fan Switch And Cab Filter?
- wtb: trenz grill
- what suspension setup are you running??
- whistle-sound from 2,000rpm-WOT + cracking sound from 60mph+...waz up?
- Drop Res MOD??
- Check Engine: P0440 &P1448
- auto tranny takes time shifting
- Injen CAI, I am confused.
- #74 bulbs for those who need them
- RSB vs. Fishtailing: Whadda ya think? (Long)
- Red switches, speedometer, etc....
- cold weather= poor gas mileage
- Airbag Light Solution
- Clutch Change. . .?
- Completley removing spare wheel well?
- eliminating the knock senson
- line pressure solenoid valve??????
- Door stop, Dome, Key and map light not working
- Y-Pipe Install
- Post Engine Bay Pictures
- Does anyone hear have a problem when reversing and hearing a clank sound?
- 4th Gen Maxima Scale Model
- two problems im haveing wit my car
- car vibrates when wheels spin
- Timing chain guides
- Tranny not downshifting
- Stillen Short Shifter
- She is blowing me cold
- HELP PLZ CAR wont start CAI
- URGENT! Hit a curb and bent front right control arm and spindle.
- Post your smoked corner pictures - please
- Are the front ignition coils the left or the right?
- Windshield Washer Hose
- O2 sensor question...codes wont go away
- How much should a rebuilt starter cost?
- did ecu test and need help
- air intake temperature sensor in a K&N cone?
- yellow fogs
- Anyone have Car and Driver or Road and Track articles?
- Maxima Saved My life and 4 Friends...
- Headlight Tinting Colors? Led mods.....
- HOWTO:Make the frount side maker BLINK??
- cant search...need KYB dust boot help
- Car doesn't start when cold....starter replaced....every test done...HELP!!
- Engine Vibration
- JWT pop- how long can you use? replacement?
- intk manifold & injectors
- Y Pipe
- pls help - exhaust system reccomendations
- Regarding Cold Day Starting Problems
- just when I thought I had heard it all...
- How much is my car worth?
- Fastbrakes
- headlights
- Change KS last night...weird problem with ECU
- quick fix for performance
- headers?
- heater fan... dealer telling me my resistors are dead
- south west auto works
- What kinda of clear corners did I see today?
- Camshaft Position Sensor code 0101 ??
- Ventilation Problem
- Suspension part list?
- Trenz Grille
- Quick Question about changin' the belts...
- people who have removed headliner or know about power vent visor mirrors w/ lights...
- Just got my 5 speed ecu.
- Outlines Lights
- sound clips or videos
- Alignment
- friends Max stalls when cold - what gives ?
- Shifting problem with RPMs......HELP !!!!
- Fuel Gauge Question
- 98 auto shift problem
- SE vs. SE-L vs. GXE vs. GLE who would win?
- need help engine light came on
- got intake and now check engine light on
- Filter-only intake issues
- 30, 60, 100k, etc tune-ups
- To the Tranny/Clutch Gurus
- Is this normal?
- ECU problem
- E-brake light coming on/off, how to fix?
- Headlight mirror finish chiped
- fog lights for GLE
- Knock sensor, amazing mechanic.
- headers
- Failed the emissions test - Please Help
- injen intake and large amounts of snow/water: my experience
- Al Bundy needs advice - '96 GXE 238K miles
- Changing the headlight?
- Intake spacers: guaging interest
- ABS light when on when I was spinning tires on ice...
- tranny fluid on manuel
- Is a '95 antenna compatible w/ a '97 Maxima?
- transmission problems
- Anyone know Trans-axles?
- 5sp swap parts question...
- Windshield Washer Fluid Idiot Light
- vibration stopping when under 10mph
- Best fuel system cleaner??
- 96 Mechanics Manual
- mevi??
- nismo product
- c/f door pillars
- High Speed Vibrations
- c/f door pillars
- Could ECU be fried???
- How do you know if a transmission is on its last legs?
- how much?
- CALI maximas meet for LA annual autoshow in JAN?
- 98 Maxima Owners Manual
- Toser Coilovers? Anyone ever hear of these?
- RPM too high? 120km/h=3100RPM (in5th)
- Error Code P0745
- Carbon fiber spark plug cover *pics*
- Never realized how crappy the stock radio was...
- Best spring for my mods....? help
- HELP!! Starter Died..i think
- One more Gauge Bulb upgrade (Pics inside)
- can i make my 5-speed an auto?
- Finally broke 130+mph
- Question about power seats
- what is causing the car to squeeling when it starts?
- Need some help guys...
- Check Engine Light - Misfire #4
- AE Headlight
