- climate control swap
- gear oil leak:/ !?!? help!
- CEL 0901,0307,0503 after sensor replacement
- 2nd Gear is back....How?
- Help with belt replacement
- WOW!!! Is this a good deal on an I30t LSD 5 speed transmission?!!!!
- High Hc's after Y
- ABS on a 1995
- Power steering issue
- NOOOB Question? 3.5 Swap
- need a new sidemarker socket
- who has blown their 140a battery fuse?
- Can a 1999 Maxima tow 2000lbs on a trailer?
- 5th gen springs work on 4th gen?
- MISSFIRE!!!!
- My car had a Stroke this morning
- I don't know if all max's are like this. (remote lock/unlock)
- GLOWING HEADLIGHTS (BLUE IS ILLEGAL)
- exhaust
- vibration at 20-25 MPH :/
- i experienced something scary earlier today. breaking + rain?
- Will 5th Gen headrests fit 4th Gen seats?
- Way around lowering springs???
- Car doesn't start, acts like it has no power even when jumped
- 99-95 conversion
- Clutch pedal bracket?
- Water Pump Install MA area
- I figured its the trend so Here is my machine
- Are Black Bumper Lights Legal??
- stripped out strut mount hole. Why?
- 1997 Maxima running rough... SES codes
- PAINT JOB IS DONE CHECK IT OUT
- A kill-all switch to stop battery drain?
- Put in a new clutch now car misfires
- Loss of power at higher rpm's
- CV joint broken or something else ?
- Need help with tire sizes..
- stiffer too stiffer, rear too bouncy, cheap solution?
- Car shaking on take off after flywheel and clutch upgrade
- GETTING THE MAX PAINTED
- New rims, insight needed
- semi-push button start installation tutorial. (6 bucks lol)
- IACV issue with 00VI engine in 99
- need help! creaking after replacing inner tie rod!
- 95 maxima injector swap
- Who makes name brand good aftermarket ignition coils?
- greddy sp2 tooo quiet...
- IACV Issue
- 1999 Hansim ignition coils- what failure mode
- coil replacement procedure
- i30 Infiniti and Maxima Spoiler - do they line up?
- ground control coilovers
- help me find "under the hood shots" for fourth gens
- Cooling fans dont turn on, fuses good....
- Roaring and Howling - Are My Wheel Bearings Bad?
- foglights not working, need help with wiring (PIC INSIDE)
- anyone have a spoiler? or know where to get one?
- Riding without passenger seat illegal?
- Which ECU's (model #'s) will fit 1996 SE, Fed, Auto?
- vq30dek rebuild!!! more hp!!!
- new o2 sensor still 0503????
- DEK Knock sensor in a DE?
- sport pedals?
- Tips on finding parasitic battery drain?
- ecu wont recognize key anymore
- anyone to help me with oovi?
- WHO has the LOWEST MILAGE 4th gen on the org?
- Whats the LOWEST MILAGE 4th gen on the org?
- Inhibitor Switch
- NEED HELP MATCHING TRANSMISSION BOLTS!!!
- to much money for miles ?
- Car has intermittent cranking issues.
- vq35 swap is done!
- What kind of body kit do you have?
- Weird Problem
- Does motorvate.ca work anymore?
- Is ths a GXE or GLE?
- 99 immobilizer Really need opinions
- Getting the Max Painted
- HELP - Clutch pedal VERY EASY to push in -Problem?
- Loose clicking noise on LF wheel when turning right
- Map lights with dome lights
- Troubleshooting O2 issue
- where to get spoiler install kit these days
- Working on our 4th gens LIVE 10-16-2010
- these good for my car?
- Maxima Will Not Turn Over
- Problem with stepping on the gas DELAY
- Junkyarding, always a surprise
- input Shaft bearing :(
- Has anyone ever experienced a scraping noise coming from an axle before?
- help with ps leak! *pics*
- clutch bleeding question
- rear strut problem..help
- Canadian LSD different from US LSD??
- Advice on car stalling
- found out I have a waterpump leak
- need help finding rear braided lines
- Maxima only starts when I give it gas.
- 96 i30 vs Maxima - Tan Leather same color?
- Need some asistance!
- how much can I expect to pay for these 3 parts?
- Found a rear set of PowerSlot rotors CHEAP.
- Lower Radiator Support
- need dryer pressure switch
- cannot get caliper off of rotor
- New Spark Plugs = Harder Start
- NEED HELP! Cannot start car
- Weird coolant leak
- do codes exist if no check engine light?
- Starter won't catch, but I think its key assembly
- maf posible problem
- pvc intake piping...
- To Buy or Not to Buy!
- i thought this was funny so decided to share pics inside
- Tips on the "leather" repair kits like Permatex?
- OBX Intake (Ebay)
- Ebay Header Kit with Y Pipe
- seafoam
- 96-97 drive pattern to reset ecu system readiness
- Began the front end rebuild / renovation
- Fujita F5 Filter?
- Help with codes /monitors please
- Rear Wheel Hubs + ABS
- Evap Control System - Code
- Drive line noise - can't pinpoint
- Anyone knew this??
- very very soft thunk after stopping
- Random starting issues, video inside.
- Sputtering on acceleration!! Need some inputs
- anyone install aftermarket alarm...
- pics of gold max's
- My "new" maxima..
- can someone with a 5 speed help me....
- Working on our 4th gens LIVE 10-9-2010
- Turn the key and nothing happens...
- Got my Gen5 Clutch in :)
- Need a new key fob!
- bad oxygen sensors? terrible mpg
- powersteering leak & o2 sensor
- DTC help!
- exhaust problem(loud sound)
- Could a Really bad Throw out Bearing cause hesitation ?
- Westchester mechanic
- 4th gen coilover options
- Quick question
- Any reason why low fuel level would trigger CEL?
- Tending do my misfire and found this!!!
- Poly Shifter Bushings
- I am wondering if fogs from a 96 max will fit on a 97 max
- OEM Rear Brake Hardware Kit P/N:44080-54C29
- just got ny megan catback installed OMG (video)
- where should i buy window motors?
- Brake Booster vs Brake Master Cyl problems: super soft pedal...sometimes
- Stillen kit w/custom mudflaps...
- interior lights problems
- How to adjust single plug TPS on 95 Fed spec. 5pd??
- another exhaust question
- wanna darken my headlights/tails nightshade or tint?
- weird eltronic device anyone know what it is pics inside
- Power antenna wiring issue
- HIDExtra $60 Kids for 97 max
- Tachometer and possible other electrical issue
- not charging only when cold WTF? new alt
- Is there a simple way to test antena assy while still in car at salvage yrd?
- Requesting picture of Throttle Body adjustment screw of YOUR 4th gen.
- '97 SE CEL Light
- Starting issue
- Parts recommended for a Suspension Rebuild
- A/c compressor bearing
- Programing 2nd oem remote
- another "help im a lowering my car noob" thread
- Taking Door Panel off, Don't be Scared to do things for yourself.
- Does an 04 I35 starter fit 4th gen?
- heated seat wiring
- 4gen: Muffler Suction?
- 99 ecu not tunable???
- strang sound near UIM and pcv valve (video inside)
- Stock auto tranny power capabilities
- Flipped FSTB
- power seat issue
- bumps in the road
- Where to by OEM replacement clutch?
- Nut Size / Muffler Clamp
- sputtering on take off
- Awkward Starter...
- Changing Muffler (oem to walker)
- Loud humming on cold start at idle in D-N-R
- where is terminal 25 on a max? supposed to be a ground
- P1445 DTC
- Road Trip!!
- It's been real...
- Broken window pulley/motor?
- one problem after another with my maxima
- Saying goodbye to my maxima...
- ECU Identification Trouble
- Please say hello to the newest member of the Maxima.Org family...
- Buying a used standard tranny...what to look for?
- Knock sensor bypass, what am I doing wrong?
- Non-steady RPM at idle! Video included.
- Nothing better to so I took a few pics. of the hooptie
- water leaking through the sunroof
- I just got an p0446 code Help..
- how to replace driver side axle?
- Help needed: A/C charging question - Long
- squeaky belt or pulley
- retrofit question
- smelling gas in the cabin area
- Doing a CSM, and saw some GREAT NEWS!
- infiniti i30 won't start
- Another question....
- blows engine cont fuse when sterring wheel is turned
- Audio Questions...
- Mysterious switch
- gen 5 clutch in my gen4... My uncle doesn't recommend it.
- Blower motor
- How do can you tell whether salvage motor is good?
- RPMs drop and car stalls
- q45 brake pads question
- 4 gen tranny issues
- FS: NIB 95/96 Rare all clear outer tail lights
- Help car won't start~
- HVAC Temperature Adjustment Issue
- De-Badging?
- Questions about body work.
- what to do first!? project or no?
- Front Sway Bar Question
- Wrecked 98' 5sp. Max For Sale
- clutch pedal issue
- have a z32 maf question who can anwser me?
- Transmission leak
- Spark Plug Choice
- Quick motor mount question
- No cold air when A/C is on
- what kind of car battery to get?
- Should I keep or sell the Max
- hids will not turn on!!!!! goddamnit!!!
- How do I seal the duct-to-airbox connection?
- Trouble light assistance...
- What are the tell-tale signs of a vacuum leak, other than CEL?
- Strongest Concentration of Cleaner?
- Anyone with LED bulbs interior light?
- PLEASE help, water pump coolant leak
- Possible flex pipe
- help with sts
- Electrical Problem...can't figure it out!
- Converting a 5sp to auto
- High Mileage Maxima
- Starter Question
- just paid 60 bucks to get y-pipe to cat bolts removed.
