- Question about exhaust leak
- catman CAI
- Will GLE Struts work on an SE?
- Corner light rewire on 95/96
- Can someone guide me on how to install a knock sensor and coolant sensor on a 95 SE?
- If you have air suspension (cylinders) on your Max, show em
- For those with mesh grilles
- Different part #'s but same spark plug?
- Car stalled/died while driving with PCM code 0804. HELP!
- Am I good or what!!!
- Charge and Break lights go in and out...
- Auto Tranny Fluid Change
- removing 3M tape
- Changing tranny fluid. Quick help please!
- All NJ maximas
- Clutch chatter
- Heavy-Duty Half-Shafts...?
- 100 watts H-3 fog lamp bulbs
- smoked a Thunderbird
- engine swaps
- 300zx clutch
- Ford V6 200hp vrs Nissan V6
- H&R install question ????
- Red/Clear Tail Lights for a 96
- A Cosmetic Mod for Automagics
- Ben's ECU Mod not working?
- hesitation up ahill
- Question about Levoc Hybrid shift knob
- HVAC fan having issues
- nos...nos...nos...NOS
- Exhaust, which one? Apex
- Who was clearing 97-99 Tails for $$$?
- paint front grille white or not for a 97 pearl wht body?
- alloy and steel rims use same lug nuts?
- My car was vandalised today!
- What do i need to run Nitrous ?
- Rubber Antenna?
- Racing the Ra***a Again
- 1998 BMW 540 6-speed HUMILIATED!
- Rear defrost vents
- making windows go up with remote???
- Ideas for pass. airbag hole ??
- straight intake pipe
- ASA wheels
- Ground Control Coilovers
- Test loop?
- european springs such as apex, B&G suspension anyone with any thought info or pics
- Car Vibrates at idle, please help!!!!!
- Attn: 97-99 Clear/Red Tail Owners *Rear Corner Light Mod*
- Prices on stuff for the maxima...
- 95 MAXIMA GLE have heated side mirrors??????????
- Black leather on a Tan interior? pimp or not?
- Got a problem - Need help (Daniel!!)
- Help install question!
- Need suggestions on type of muffler --->
- Rear Window Re-seal
- Spark Plug Replacement
- car stoped
- Knock Sensor Install
- need info on body kits
- Vibration Solved, Sort of...
- Foglight is OUT!! What the F!?
- Interior Neon Hook-up
- Spring Question????
- Corner Lens LEDs??
- 300zxtt injectors can they fit on a 95 max
- Help! A screw fell in my defrst vents!
- How do I make AE Headlights?
- Red/Clear 97+ max's, how well does your rear-end match?
- Se Rims
- Headlight Connectror Failure
- Where to get interior LED's for 95 GXE.
- coolant sensor knock sensor
- Cluncky suspension after Intrax install?
- alarm question
- DBM: Which is safer? A tight acc. belt or a loose one?
- Max Sighting in Oveido
- Didn't like ECU read outs(NEED HELP!?)
- Scratch on Rim Help!
- PR upper piece
- Brake Lights
- Tint/Suggestions
- will rims off a mazda mx6 fit my max?
- Burnt our LED's?????
- Help Me.. Quick
- Camaro vs. Me - I win
- how important are the shims on the brake pads?
- DBM Re: Brake lights
- oh no... my max has high mileage
- Anybody selling stock rims and tires off of a 2001 maxima
- Popcharger causes overheating??
- window tint question???
- Valence Grill question
- A Crazy Crazy Mod
- The best ground effects for $
- How much horsepower ?
- Emissions with a Y-pipe?
- Another antena question
- Adjusting Fog Lights
- installed eibach/tokiko combo making noise..need help
- Nopi,altezzas.pics!
- Pop-Charger or Drop-In Filter
- anyone with a Y Pipe and got a check engine light .. HELP
- Passanger window auto down?
- Tokico and Eibach setup on a super black max
- i got code 0304 and 0302 OXygen sensor price$
- Rear Sway Bar questions
- engine swap
- My Test Drives while max.org was down!
- power antenna question........
- Short throw shifter from custom maxima->
- exhaust system scaping on bumps
- Possible to run in 13's with bolt ons ?
- Engine idle rough..please help!
- What is the best intake for someone on a budget
- Sugestions for which 12V source to hook up INDIGLO pedals to...
- Removing/installing the driveshafts
- When Dropping Tranny- does exhaust need to come off?
- Who make the best clutch?
- E-brake problems....need advice
- Need Help
- Need brake pads advice
- Bosch platinum +4 come here.
- Car pulls after FSTB install
- what kind of shocks???
- different size tires f/b ok?
- Attn: Daniel B. Martin or Anyone!! Cruise Control Problems.....
- Fast Idle Solenoid ?
- DBM,any one that can help.. brake light fuse
- Need help from Daniel B. Martin
- car is stalling and its not the idle
- Max mod's
- HELP!!!! Standard Transmission
- Koni's...how to adjust the rear?
- beat by a clk 320
- poorman's short shifter
- Guage (AutoMeter Install) Questions
- Camber Kit for the rear needed with Eibachs?
- First Dyno
- Mobil 1 ATF. Any good?
- To all with Sprint springs...
- Attn: Cumalot
- URGENT HELP: having problem attaching EL INDIGLO acceleration pedal onto stock pedal
- Diagnostic 0304 , 0302 read the sticky a few Q's Still
- 4th Gen Back Up??!!
- I talked to a KYB rep yesterday...
- My race w/a S/C'D RIVEARA
- Had fun tonite burning some unfriendly drivers 2 eclipses, new prelude, supra....more
- New Pics Of My Ride:
- Trying to remove spedo with no sucess
- Help - Need help with paint issue.
- Which Springs to buy?
- Gotta buy another set of clear corners...
- Bose headunit problem
- nopi nationals just got home-long
- 4th gen w/Tantraums..pics?
- Paint on my 96 maxima look different!!
- Anyone have a CarFax code that I can use
- Cai
- Changing motor oil
- how to change bulb behind Gauges for 1997 GXE maxima
- 4th Gen Erebuni body kit pics???
- I need more speed....
- Drove IS 300 Today!
- 0304 0302 Diagnostic codes
- Please help me chose front calipers.
- Anyone ever replace the battery on the keyfob??
- Main Fuse Block bolt with orange indicator
- have you seen this SMX pic ?
- how does a maxima do vs a grand prix gtp?
- advice on wheel/tire combo
- 95 vs. 96
- pace setter exhaust!
- Maxima Haters
- 2002 maxima engine
- need your opinion...
- if you had to pick one mod!
- Always bleed brakes after pad install?
- HELP! What is wrong with my dash?
- Funny noises...CV joint???
- Warpspeed.
- What's a good 1/4 mile time for a 96 auto with...
- Ran at Commerce last night..... ehhh I don't know what to think about the results.
- HID's "come and get some"
- Just Installed Cattman Y-pipe, got a few questions.....
- My Maxima spaniked everything tonight
- Cut bumpstops?
- Strange "clicking" noise coming from the dash
- would the onepeice cefiro headlights fit on my maxima...
- Stupid comments made about my car tonight..!
- My car acting weird!
- Max sighting : Buffalo NY
- does anyone here have a Remus Muffler?
- Whoever said UDPs don't work? Got my best trap speed ever!!!
- how much do stock 96+ GXE wheels weigh?
- Speaker Replacement in a '96
- Pop Charger
- maxima of the month
- Brigboy Mobile Is Rollin on Eibachs....
- governor question:
- How To Rewire Lights???
- Cosmetic Recommendations
- another rim question....
- anyone cut H&R springs????
- Aftermarket Seats
- Kills galore, 2002 Civic, 90 5.0 rustang, etc.!!!
- I30 rear seats fit Max?
- would this rim fit on maxima?
- why replacing platinums at 60k not 100k?
- JWT NOS kit
- next performance mod????
- Drag with Honda
- Spotted 4th gen in FT Collins
- ABS Light On
- SE Badges
- Interesting Rattle...
- Found the cause of my roof rattling
- Quick flywheel question...
- My CA bought max has FED SPEC emmision sys???
- fuel smell in cabin
- General Maxima Discussion?
- "GLE" badge on trunk??
- Deer 1 - Nine7Max 0
- Any one with the sarona back bumper plz post pix thanks more--->
- Light Bulb Questiion?
- people with the unorthodox UDP, please give me advice
- new pics of my car
- darn it...rim is scratched up...how to fix?
- budget y pipes
- RE: mumbo jumbo
- ? for DBM or anyone regardin Fast Idle Solenoids
- RE: tranny
- aftermarket strut mounts and strut bushings?
- Wet Tires
- Best quality replacement bulbs?
- Max broken into
- If you know any groupdeals sites for Maximas enter here it may help everyone
- 95 GLE Auto Transmission
- my fuse keeps blowing...
- Check out this AUTOMAGIC
- Exterior!
- After-market parts
- ot: kick panels
- Kobel Image Styling Kit...
- Legroom: relocating driver's seat?
- Anyone with Apex Springs - thoughts
- headers
- Coilovers: pros and cons?
- thoughts on a twin tip DTM muffler?
- Aftermarket rotors?
