- Alarm bypass needed for 98(shaved door kit installed so options are limited)
- O2 sensor bank 1 sensor one...
- seatbelt help
- 95 96 rpm problems
- Upper intake manifold bolt size
- Multiple engine light codes
- Ignition switch woes
- Did wife trip the immobilizer? 99 max
- Coil Pack Question
- Timing set
- Ignition Coil Plug Wire Broken
- 99 maxima will not start
- code p0303
- 20inch infinite qx70 rims ?
- Havent posted in a long time.. Update..
- Suggestions on wiring foglights(car is not prewired)
- ABS Speed Sensor cable split
- Air bag light problem
- Front (Passenger Side) Engine Mount Replacement Help
- Passenger side power windows/locks/lights don't work
- Spark plug recommendations?
- Tranny metal on metal sound?
- 95 Maxima,Help!
- help please with my first big mod swap 5G engine in my 1999 maxima
- 95 max. brake pedal "sometimes" goes almost to floor to stop.
- Catalytic Converter Question
- Vacuum Hose Sizing
- 99 Radio Question - Non-BOSE System
- Front right whine - seal or bearing?
- 1996 maxima gle 00vi swap intake
- Door lock cylinder loose
- Car wont maintain an idle
- wiring harness question
- Cowl Plate Removal? what holds it in?
- Pipe Box on intake under battery? Funciton?
- P1105 - Map/baro? OR Tranny issue?
- P0400 never goes away
- Secondary intake air scoop makes 95 maxima faster
- Coolant recovery bottle
- Service Engine Soon light not going on!
- 4th gen. Max vs. new cars - what do YOU like?
- Oh my goodness......
- camshaft position sensor still leaking
- Oil leaking into exhaust.
- 95 wont start
- New or remanuf'd axles - the good and the bad?
- Almost stalls accelerating from stop
- Name of hose from valve cover to valve cover?
- Cooling System change/flush - drains? risk? difficult?
- What to do
- heating fan resistor location - or other evap access?
- 1999 nissan maxima cranks won't start up
- Unable to clear check engine light
- Replaced alternator but now certain electronics won't work
- Stall after highway driving + codes
- Keyfob Issues
- Well - I bought another 4th GEN today
- this blows me away.....
- 4th GEN GLE BCM Replacement
- 99 CA spec hard to start.
- Scraping noise when shifting into second
- Belt sqeul
- Direction of stock cat install?
- P0138 / O2 with new exhaust install
- AC problems
- Creaking when getting in or out
- Pouch under rear bumper?
- water on passeger floor question
- drain hose for Air Conditioning
- How to disassemble alternator's connector
- Knock sensor
- going crazy
- Head gasket job Timing chain problems
- Front End Clunking Noise - Wheels Go Inward When Car Lifted
- Running Rich Im stumped.
- Check engine light came on
- Maxima Won't Start (video included)
- Hey Guys ... Lookie What I Just Got ...
- Car still stalling
- Tachometer problems
- Projector Headlights
- Coil overs and exhaust
- Stalling problem..
- 99 Max SE A/T Rear Axle assembly rusted and rotted
- Cat grounding strap - needed?
- What's this plastic part from under my car?
- Maxima help
- Iacv port?
- 99 to 97 Harness Ecu swap
- Lowering
- Ignition coil boot stuck on snapped plug
- Help finding compression
- Idle adjustment help
- looking at a 97/98 maxima, but.....
- Trunk only occasionally opens
- Radiator fan not coming on
- noisy compressor
- CV Axle
- MAP Sensor Relocation?
- Anyone recognize this Max?
- Seat belt problem
- Yellowing headlights on side view?
- Upper Oil Pan question
- Question on Maxima radio
- 1996 Maxima build
- Ok, need some help guys..
- NISMO Shop West Covina Nissan
- 1995 and 2000 maxima front end
- Multiple parts for sale!
- engine electrical problems. need electrical brains.
- Possibly Getting another maxima
- CV Axle Choices
- Temp Gauge Problem
- Stainless Steel Warpspeed Y-Pipe ...
- mystery connector ID needed
- Alternator sub harness retaining pins
- Optima Red Top lasted 26 months
- EVAP Purge Cut Valve
- very strange clutch/pressure plate problems
- Can some one please decode CEL (Video)
- Power steering reeservoir hoses leaking?
- looking for a battery hold down ill
- Re-pin or wiring harness swap??
- Rpm gauge issues
- Exhaust smells of raw fuel/poor mileage
- 1997 Maxima, dead after sitting for 4+ hours
- Instrument Cluster Lighting info
- 1996 SE mil and inspection
- Dash lights come on when I brake
- Lowered 2" and new axle already popping
- Just a headups guys
- Need length for AC Bypass Belt
- Jim Wolf Tech Pop-Charger Photos?
- drivers side wheel rubbing on right hand turns...
- Exhaust system
- Crunching sound on sharp turns
- 95 maxima "jumpy" while driving
- Engine light Boggled
- $24 Ebay MAF worth trying?
- Resetting Ecu Screw is gone :/
- idler pulley woes
- Help! Where does this hose connect to?
- Scored a free 97 Maxima. Possible.. Cat?
- Serpentine belt screeching!!
- Black spots will not come off?
- Where can I find another MAP - BARO switching valve?
- ABS light on and AirBag light flashing
- headlights
- Need to paint front grill
- What happened to my clutch (with pix)
- Front Pistons 1996 SE
- I Love This Forum!
- does anybody know what this part is? (dangling)
- woooohooo I'm driving the Maxima today!
- Please help new max
- P1335 trouble again...
- need help with ECU purchase
- Do I need a new harmonic balancer?
- Either I am completely insane or completely genius (Part 2)
- Remove manual tranny without removing center crossmember?
- Shift linkage
- Brad Penn Gear Oil?
- Doing clutch- replace flywheel too?
- Fog lights
- auto shift knob replacement
- Does anyone know what size nut this is?
- Help; i need to get rid of the check engine light.
- ABS on after replacing Alternator
- Fog lights
- O'reilly Ultima reman alternator lasted 9 months
- Need help with the power steering pump
- Reaching out! 97' maxima cyl#1
- 97 Maxima shut off problem
- Clutch doesn't fully disengage
- Direct Engine Swap
- Improving stock y-pipe's flow
- permanently mounted fuel pressure guage
- Need some help here
- strange noise in front end
- 98 maxima 01 11 code showing
- Cruise control
- Too much gas.
- grinding noise accelerating when turning
- 98 SE upgraded to '16 BMW for free
- Upper radiator hose
- Monroe Quickstruts Dissapointing
- 1999 Se idles out and dies while stopped
- Rear Oil Leak, Rear valve cover?, Parts Needed?
- Power Steering Belt/Set Screw Replacement
- New Here. Inherited a 98 GXE. What now?
- 95 Maxima GLE wont start
- REF crankshaft position sensor bolt broken
- 98 maxima camshaft position sensor o ring size
- Mystery loose connector and crank no start issue
- Ideas to get this rounded bolt off egr guide tube?
- Battery dying while driving
- Anyone know what these missing pieces are?
- Will 16 inch rims from a 2004 Chevrolet Cavalier fit a 1996 Nissan Maxima?
- Max won't start or crank
- Any suggestions?
- Looking for decal
- My door is stuck closed
- 97 Max Power but not starting
- ce light tells me 02 sensors bad, but they are testing good...
- Is this a sign of a bad axle?
- Put brake fluid in power steering; need to flush?
- 5th gen engine on 4th gen transmission?
- will 6th gen alternator fit 4th gen?
- CV Axle came out of the transmission while doing a strut job
- Help! What is this on my engine 😡
- LED Headlight Bulb for Retro-Fit Headlights
- 98 se I believe
- Test alternator in wrecked car?
- 96 inner tail-lights w/ 97+ trunk? lol take a look
- Euro Headlight
- New valve cover gasket leaking after only one week!
- Front Wheel Bearing Replacement
- The End has come for My beloved Max
- Smooth out Engine
- ignition key cylinder replacement
- vibration in gear while stopped.
- best gap for spark plugs
- Left turn signal stuck/No right turn
- door jamb switches
- iridium or platinum spark plugs
- OE injectors......Hatachi or JECS?
- Alternator died? Where to get new one?
- Jerking upon accel? MAF, fuel pump?
- Ive Got An Oil Seep ...
- A/c clutch problem
- Wheels!
- 96 Maxima Rough Idle/Misfire
- Replaced ignition switch
- Squeaking noise at 30mph-cause?
- OBDII scanner/ignition timing/octane question
- Bose speakers humming noise at low sounds?
- Car starts, then makes a high-pitched sound and dies immediately
- Replacing head unit, stupid question about wiring
- Which way do the spark plug tube seals go?
- Broken hoses during valve cover gasket replacement
- Starter testing fine, but struggled to start even with new battery
- Stuck in a rut
- Timing chain life expectancy
- anyone lower the front only?
- Detached hose not sure were it connects
- Leaking oil near this thing...what is it?
- Selling my beloved Max
- [Help] *Video* Hard Start 97 Maxima
- Lacking info in Stickies!
- Steering Wheel Horn
