- Would you want to replace both tie rod ends, or just 1?
- Opinions on clutch to pair with act pressure plate.
- White stuff leaking from car
- ABS self-diagnose info doesn't match actual car
- Strange oil leak
- Is this coolant too old to use?
- Aluminum MAF adapter?
- Vibration. Check engine light. Burning smell.
- Fix defroster lines or replace rear windshield?
- Clutch master slave - brand
- alternator going out?
- One (1) Timing Chain Tensioner ... Yes?
- Clutch going bad?
- Fog light reflective material fell out??
- Stalling when idling issues
- What do these Engine Malfunction error codes mean?
- Bad Misfire 1997 Maxima (no obvious codes)
- starting issue
- Car vibrates and stalls. Check engine light.
- serious issues starting and misc....need help! fast....
- Wiper Motor Linkage Orientation
- Did I cause any damage? Drained coolent and blow air threw the lines
- Light tapping noise coming from engine
- Possible BHG?
- Kyb struts and lowering springs for $$$
- My muffler exploded...
- What's a good place to order control arms from?
- Cattman Headers generation differences?
- Struts and Springs
- Broken ruber in the middle of the direction parts
- An O-ring experiment i did.....
- engine revving but cars not going
- Emanage blue guros
- Trouble on Start-up
- water pump weep hole location
- 95 mAX weird engine noise, and wine
- 1995 maxima se --- power antenna connector???
- Best place to buy screws?
- Help!! Cant Get Water Pump Out!!
- Car starts but won't move in Drive / Reverse
- Grounding 1998 maxima vtc's
- Just fixed antenna I have an extra harness/wire!
- Where to pick up 12v in engine compartment with ign on/start?
- 96 Maximum Rear Brake Issue
- Should I use my car in extremely cold weather?
- Knock sensor harness
- Timing Chain Question
- Minor things I have noticed...
- Fuel Tank cracked question.
- need some help with a fuel leak
- Will this lower support bar work?!
- nissan maxima 1999
- maxima going rouge
- Resetting the security system on your Maxima
- What's a good place to order parts online?
- 95 Maxima SCARY swerving! Need Help!!
- Odd electrical problem
- Fender bender
- Happy New Year 4th gen owners!
- Need to reset radio after every start
- 97 max, Doing the power steering pressure hose job...
- Is $500 enough to change from 96 to 97 style?
- 96 Maxima EVAP Question!!!!
- My 900 Dollar 95 GXE 5 Speed
- PO1320 code
- 235s On Stock 16s?
- transmission cooler line replacement q's
- Starting problem CEL p1335
- Also need opinions on potential 4th gen.
- P1335 code help please
- Need opinions on potential 4th gen
- 1995 Maxima won't start
- Low heat, low temp on gauge
- Is converting a five speed to a manual easier than changing the engine?
- Moon Roof Air Deflector Damage Control?
- auto transmission slip when shifting to 2nd
- Fuel Line replacement
- Ugh... Car accident 4th Gen down!
- Grounding Kit
- Looking for suspension suggestions
- RPM dipping at Idle
- Coolant Recovery Tank Replacement ... Recommendations?
- Will this fit?
- No turn signals, no flasher
- RPM issue and sputtering
- Production month
- Strange clanking noise after replacing some front end suspension parts
- 22 inch rims on a 96 maxima
- What is a standard warrantee for a yard engine?
- Friend has a used engine would it fit?
- Z32 Brake upgrade brackets
- Ecu tuning and chip Qs
- how do i replace a water pump?
- How to bleed cooling system?
- gas leak
- The bolts in the middle of the mounts under the transmission
- Valve cover gaskets leaking
- Harmonic balancer making loud noise after squeeking for a month
- i need the egr valve tub. helppppp
- Max rides like an empty dump truck
- 2007 Maxima Seats in a 4th gen, how hard?
- Are E-brake handles universal?
- Probably getting a new max
- Greetings! new guy here
- are both the egr tube gaskers the same?
- 98 SE Running Smooth--knock on wood
- Wheel bearing question
- 96 Clear taillights
- WTF is wrong with my max???
- Poor gas mileage, heat issue and leaking oil
- Rear left brake light problem!
- 95 Max runs rough at stop light and in reverse
- Thoughts on Catback?
- Locked keys in trunk - dead battery (also in trunk)
- Diving into the 95 Maxima heads, I have a few questions
- Screwed up differential? Can't get drive axle to locate.
- LUXURY DEFINED 4th Gen VIDEO
- Steep snowy driveway = ABS light on
- Trunk is leaking when it rains
- Timing Chain Clatter (Tensioner) or Something Else?
- Is there a guide for a J30 seat swap?
- Maxima or Cefiro
- New PS & AC/ALT BELT
- 99 Max low beams inop
- How to remove side mirror inside triangular cover?
- Air intake temp sensor
- flexplate access plate
- thinking about a exhaust upgrade
- Anythin in common?
- Connector questions after engine replacement
- wet weather problems
- Hi, don't mean to sound obtuse but how can I screw up a gear ratio?
- Please help! Car wont start after several turns and misfire
- Maxima Front End Crash\Repair Questiond
- new lloyds custom mats
- Need new front personal light bulb
- Scannerdanner maxima misfire case study
- Car dies out plz help
- are the automatic transmission normally good?
- so i went to go.....
- Clogged Cooling System?
- test pipe
- Idle neutral rpm bounce
- Fuel injector cap replacements?
- Replaced tranny-no go!
- Trailing arm bushings?
- Losing Coolant recently when it's cold outside
- Fixing up the bose stereo stock bulb burnedout.
- Questions on Cylinder Head Gasket Repacement
- happy birthday maxy!!!! ( 95's chime in !! )
- anyone else have the body trim around wheels??
- Time to Repair or Replace?
- blew a head gasket.
- replacing the windshield washer fluid reservoir
- 1995 Maxima Jerking and hesitating. Won't start.
- Very hard to start
- Idle control valve
- Starting issues
- How to replace starter solenoid?
- Maxima Questions.
- bucket seats installation
- Will this cluster fit my 96 i30?
- Tuning. a 95 the right way.
- radiator top mount
- 96 Maxima - part out or retire?
- Brake help!
- ugh... more problems with the max, Now misfiring when cold
- How to really Test Coil packs.. Help!
- 3.5 swap question
- Fuel Filter hose
- Disconnecting the battery while engine idles, stalls the engine
- Hats off to member pmohr
- High Beam indicator on dash flashing
- Stalling, knock codes, idle drops - cause?
- 1999 Max - fuel smell in cabin
- Looking to get a new Cat
- Do I need a head Gasket????
- Problem after installing struts. Do I need an alignment?
- complete interior revamp of my 95 maxima
- What size bolts on torque converter?
- emissions time again, what steps to pass....
- does ABS really do anything?
- 97 Max Starter Sig Fuse Slot Location?
- 95 maxima refuses to pass Maryland inspection
- 1998 Nissan Maxima Heat always on
- So gas Tank Strap broke off. Where can I buy stainless straps?
- do i have to remove exhaust to remove a transmission?
- 4th gen interior swap
- High Idle At Cold Start
- code p1606 help fix
- Car has problems starting
- if you happen to misplace the bolt that goes through your motor mount...
- the car is back together, but stalls as soon as it goes into gear
- Interested in seeing whats under your hood!
- Axles + bushings + strut fix - what else?
- Identify Exhaust Sound?
- engine oil leak
- I hit the curb and the curb won
- Cool video of the 95 Maxima
- Fogs are in
- heat not working
- Any suggestions welcome. New here.
- Please help diagnose stalling
- Howto: Analog to Digital cluster swap
- 96 ecu to 99 maxima
- Locked keys in car! Help
- Will this catback exhaust fit in my 1996 I30?
- Timing chain noise
- 4th gen total weight
- too much oil.
- 97 SE code 1003, Reverse issue
- How to tell if I have a standard or limited slip auto trans?
- bouncy coilovers?
- Well...glovebox and wheel locks
- Cranks all day, no start...alarm related?
- Turn signal lights up but wont flash on '97 Maxima
- Temp is in the red. Just completed a radiator flush.
- Where do you buy OEM part?
- Please read - throttle stuck open my fault! (Pic)
- Wiring trouble, maybe ignition?
- Two cooling fan fuses...oh confusion...
- what size bolt is needed to mount the alternator
- Engine flexing
- bogging/stalling after car is warm
- need Motor mounts again. Best way to go besides ebay?
- Check engine light + left high beam won't work on a 1995 Nissan Maxima?
- hesitation
- 1997 Maxima GXE Auto, Erratic shifting
- Is there a mod to install heatpads? in our seats?
- any guides to removing and replacing automatic transmissions?
- Mysterious leaks after replacing window motors. Or A clog under windshield?
- Dirty UIM coming off for cleaning, what else should I clean while it's off?
- Downstream 02 Sensor?
- 1996 max
- Anybody try putting Rx8 wheels on the 4th gen Maxima?
- Transmission Vent Hose Leak
- Very loud bearing like sound on med to hard Accelration?
- Dies after 2miles
- Aftermarket Performance headers?
- Still Have Bad MPG in 1997 I30
- scanned for codes p0325
- Anyone ever buzz off those 3 little nubs on the face of the headlight?
- Alarm chirp issues
- 1998 Maxima Knock Sensor
- How to get rid of the annoying ringing sound in your steering wheel
- what can i do to win? do i stand a chance?
- cluch slave clynder is leaking. Thinking of SS line? Are they still around?
- 99 maxima dies when put into gear
- need clutch for 1998 five speed
- 96 tails in a 99
