- Rust Problem
- steering wheel
- 96 Auto Tranny DEAD???
- 100k Tuneup
- Paint Swirl Question...
- how to reset deployed airbag module?
- Clunking noise from the engine on acceleration...
- Anything tricky about changing the rear brake pads on a 98 Maxima?
- new tires
- I have traction problems
- question re: rear spoiler on
- squeaky brakes
- hopefully buying my friend's maxima, few questions
- Dome Lighting
- Exhaust! Help!
- ECT Sensor
- locking lug nuts
- Y pipe
- help with shifter?!?!
- Camber Kit
- Custom Ashtray Switch Panel ***PICS***
- Where to get Rear sway bar?
- "True clear corners" link&pics inside
- How much is this maxima worth?
- brighter corners (again, i know)
- What is the best setup?
- evap control system ECU codes
- CEL on and got weird diagnosis....
- 5 Spd Owners Help!
- Father and Son Nissan Rivalry
- Weird noise, not trans bearing, and not trans related
- Water in Spare Tire Well
- MAXIMADRIVER.com IS BACK UP
- UDP now or later - belt replacement
- My Max is down on power.
- fstb question
- Rims
- Water Wetter: Is It Worth Using?
- Anyone have a Budget test pipe?
- Exedy Clutch vs. ACT clutch
- NKG Copper vs. NKG Platinum
- 97 AT - 97 MT Conversion - ECU
- want to get y-pipe ..but what is sound level like after install
- Would *LOVE* to see some pics of nice trunk installs (stereo)
- My kingdom for reasonably priced Konig Zeige center caps!
- Gotta get rid of this Apex-i WS muffler...
- Spark Plug Torque
- CAI or pop charger?
- Idea for filter for in-cabin air circulation
- ECU trouble codes
- Where can I buy the best muffler?
- MEVI installation
- Cheapest place to get Knock sensor
- Windsheild washer motor
- Mevi
- For all the SC Maximas
- Wings West Touring Style Wing?
- Modding questions-What to get-3 senerios
- has anyone used Marvel Mystery Oil in their max, any good results? or risilone oil?
- Clutch recommendations
- few quick questions on mods
- Brake Replacement Questions
- gauge pod wiring assistance needed
- 1995 maxima clock
- Lights that need to be changed?
- thanks
- Knock sensor wiring.
- Ever use Top Engine Cleaner?
- My maxima makes weird noises
- Which Filter for Frankencar
- Need shortshifter and a new clutch
- fastest 4th gens
- need advise on cooling fans
- Strut question and diagnosis.
- Hood supports
- Whats wrong with forum?
- Help Maxima rpm's won’t go pass 2000
- speedometer head
- Car running through oil like me through alcohol!
- Two Tone Leather Kit
- Wipers?
- ECU wiring diagram
- Sylvannia Light Install
- Got a question about putting 5thgen muffler onto 4th gen
- vqpower.com website HOW TO section
- 1995 Nissan Maxima GLE fog lights installation
- Antenna stuck
- Vehicle speed sensor
- Happy : Like Pig in **** !! (rims, etc...)
- Installed Y-pipe: Drowning sound
- How many belts do I have?
- When hooking up the Harlan to the coil...
- Question about bushings
- Follow-up on EVAP repair
- Dragging calipers?
- idels great but at 1100 rpm
- My updated Sounddomain Page
- Stockpiling all winter, time to install (pics!)
- Odd question for those with larger than stock wheels
- hood strut replacement
- Wheel bearings
- new info about air bag light for DIY'ers check it out
- car steering hard to the right
- Difficulty judgment
- Which strut tower can I mount my cap on?
- Gen2 Gunmetal Altezza pics
- How to convince my friend to buy 4th gen?
- cylinder psi???
- Killed a wanna be GT R accord yesterday
- Another Knock Sensor Question!!!!!!!!
- Digital clock
- Things tend to snowball with these cars... :)
- engine hesitates plz help?
- Auto Transmission Fluid/cooler...Quick feedback needed
- Another hyperwhite question
- Clutch & Flywheel
- is300 yellow fogs on max project
- Scared of modding? Put you fears to rest!
- cracked stillen lip
- Manual Shuddering??
- help why is my maxima feeling like its jumping when i take my foot off the gas
- sylvania headlights
- Tires
- need some help in finding a place to buy a KS
- Maxspeed-Cut?
- finally installed my fstb
- Took me 9 hours ...
- 1. is it possible that my motor sunk? 2. motor mounts ???
- what happens if i put my rims on my friends Prelude?
- check engine light because of MAF sensor problem?????
- How do you find otu if your ECU is nto working properly?
- Need Rear bumpstops
- sad-depressing-gloomy-miserable-heartbreaking NEWS about my max
- Which Rotors to go with?
- If u have access to 3rd gen and 4th gen. max, help...
- Rear Heated O2 sensor AGAIN?
- Please help, no power to dimmer ie speedometer and tach!
- UPS man brought me some goodies!
- 95 maxima Keyless Entry Q...
- Voting for performance spring in term of driving and handling, not for look
- painting your own dash
- I found my problem! how much power is this robbing?
- Installation of 95-96 Stillen Lip...
- air bag questions
- overheating? a.c. doesnt work all the sudden???
- automatic gle to manual.
- cheapest place for knock sensor...
- G.D. Exedy Stage 1 Clutch
- bad O2 sensor
- "Check engine light" experts needed..
- 2 or 4-wheel alignment?
- KYB AGX. Need Help!
- Front Strut Tower Brace
- Anyone know where I can find longer wheel studs?
- what size muffler should i get????
- ECU removal
- poorman's intake GT-R?
- looking for factory workshop manual
- Fuel injector cleaner
- Got an uneven drop with Dropzone springs..I think
- rear O2 sensor question.
- Keyless entry
- how to test coil packs
- idle fluctuates under warm start
- Maxxtunning's Exedy Stg 1 Clutch
- How do you take the e-break handle off?
- Do you have to drill to put this ebay CAI in???
- Always On Cruise Control
- Need Help With My A.C.
- Is there more to cleaning the Throttle Body?
- Radio Swap with Pathfinder
- help with ECU
- Bad scraping at wheel
- SE Suspenion w/ just spirngs
- very strange Max performance prob.
- How to change CV boot???
- throttle body cleaning
- winshield washer nozzles
- Very loud sound after Eibach Spring install
- rewiring turn signals..
- EGR Valve
- Need Part number for AE pedals and 350Z dead pedals
- 99 auto - engine stumbles when in drive with foot on brake
- Sounds from behind the glove box
- to all those with 95-96 ecus in 97's and up
- Looking for pics of Black Carbon Fiber dash kit installed
- 29 MPG on a highway trip...
- Dry rot on tires
- wided tires on 4th gen?
- High Mileage Oils?
- Ticking noise
- 95-96 vs 97-99 tail lights
- skyline kit installed
- 21 lil questions (21-19)
- One touch sunroof feature - directions
- Increasing high-pitched squeal/whistling/rubbing noise with speed
- Apexi Exhaust?
- i need an exhaust for my 97
- power steering fluid question
- Transmission Fluid Change
- quiet muffler?
- opinoins on weapon r coilovers
- Hitch
- 99¢ will get you 10-20HP
- VB Mod shifts
- Congradulations William G!
- newly paint job
- Oil leek.. possible causes?
- LSD 4th gen question
- budget b pipes for 95-96
- whistling noise coming from passenger side back area?
- Wet Trunk Blues
- Car smells like rotten eggs, not inside...
- dual exhaust pics of installation
- Adding engine compartment light
- Burning oil?
- Non-bose Stock headunit problem.........please tell me it's just a fuse.......
- MEVI "FAQ"
- New mod and it's FREE
- Failed ACT Clutches
- base line dyno run
- i want!!!
- anyone have pics of an F-ed up tranny? anythin?
- Mod Impressions(long)
- ECU fault code 03 02
- HELP - Headlights Keep Burning Out
- Upgraded Seats
- Transmission Oil Cooler
- Rt Cat,worth It??
- KYB AGX's and Progress spring installed
- pathfinder throtle body
- new keyless entry module?
- trunk light fuse
- Where to buy rims?
- Need numbers of Coil pack wires that connect to the ecu for a 1996
- Whats the difference between MTL and MT-90 fluid?
- Problem with self-diagnosis on ECU.
- Help diagnose clunking noise -- not steering related
- 1996 sensor in stock air box?
- Headlight bulb replacement.. Closest to HID
- K & N Cold Air Intakes?
- Carbon Fiber Hood - How many lbs. lighter than stock??
- What Brand & How Much ATF needed?
- will r32 headlights fit a 4th gen?
- 42mm offset okay on a 17" rim?
- Feedback from people wih progress springs
- motor oil: dino to synthetic
- customaximas projectors
- INJEN is the only CAI that doesn't require drilling, right?
