- ** My Oils Leaking (help)**
- bobbly
- 17's and 18's + no drop post pics...
- Easiest way to wire a kill switch????
- springs w/o blowing struts??
- Greddy SP1 hangs too low...anyone have this problem or have pics?
- 3 pictures of CE type II spoiler...
- High RPM problems.
- How to pinpoint where a tranny leak is coming from?
- 3.5 swap???
- Help would be GREATLY appreciated. Ticking noise.....
- Gas and Temp gauge problem and also saw some smoke
- Sanded Headlights. Need Help
- Knock Sensor
- Purge Valve
- question regarding retro'ed cefiros
- More grille choices (pics)
- Remove transfer paint from accident
- Anyone ever insulate the wheel liner?
- Some foglight questions...
- Where is fuse 51?
- What do you guys think ?
- oil pressure sensor
- Can anyone help me out
- One more on 20' chrome, who is next lol
- Can I put cone filter on air intake?
- dont buy from umnitza... need help identifying bulbs
- Car Is Apart, Can"t Pull Passenger Axle Off!!!
- Ksport riders check in
- Garage advising: EGR hose+valve...
- Hks Sport Exhaust
- Where to get the clips that hold the spoiler to the trunk?
- Got bored this weekend....
- Unusual noise coming from headers-99max!
- Trunk liner/carpet + letters
- Hard to Start
- Owners with muffler tips check in...
- Brand new set of four kyb agxs for sell
- how to install jdm 1 pc headlights???
- approaching governor
- Code:p0443/0807
- Uh oh, wrong cat?!
- Interior Painting
- Car won't start
- Ignition Switch going bad?
- I have a huge problem....Thrust washer (cam)?
- These effing belt tensioners.
- P0340 and P0301
- Intake Manifold install problems
- 95 feels like new car :)
- Metal braid on flexpipe
- CA to Fed Spec Exhaust manifold conversion
- Sway bar help?
- please post photos of your piston tops
- do 02 sensors effect gas milage?
- Fast when cold..... Slow when hot......
- Rear Strut Mounts
- Transmission Shift Lag...PLEASE ADVISE
- Auto tranny slipping
- ATF? What type do you use?
- I hear squealing when the car starts...what is it?
- * Gear Fluid/Anti Freeze Leak ** HELP
- 95-96 Fog Light removal
- ** Stage 1,2,or 3? **
- 93 octane, where do you find this stuff?
- 02 bung on greddy sp2(bypass 02 sensor)
- e-brake light always on.
- Maxima Low Gas Mileage
- is this a rear main seal leak?
- A/C Expansion Valve??
- sub frame rust - what can I do?
- Got bored, did a little mod. 56k GO HOME.
- Springs Time!!!!!!!
- 16" 97-99 maxima mags
- Best place to buy Knock Sensor?
- cefiros
- $140 for a y pipe install?
- god damn otto racing FSTB
- 0304 knock sensor replacement
- my alarm keeps going off
- Do I need a new battery?
- junkyard tranny owners??step in
- No Rear Sway Bars On A 4th Gen?
- Wheel size question
- For those who changed their knock sensor themselves?
- ??????? DropZone Racing Struts/Shocks+Springs
- ABS Codes - Manual Pull
- How could I switch Bose to Navigational??
- Does Maximas Have 6-Speed?
- Greddy SP2 catback found at pretty cheap price
- help: rpm does not go past 2k...
- starting problems
- Pinion n rack should i replace anyone ??
- VQ35 cam adapters
- 95-99 leather seats 2 hrs left
- Fixing the bose
- Sagging rear 97 GXE maxima????
- Turbo?
- My 2 Car Pics
- BBK Finally Installed
- Who is SSautochrome??
- my 300zx brake calipers
- Anyone have Blehmco stage 1 or 2 lower tie bar
- emissions and saftey check
- belt wear and tear/.
- Do EL "Maxima" Door Sills for 4th gen exist?
- Looking for perfect switch for the DR mod
- Alarm system help!!! anyone??
- 95-96 grill without Nissan Symbol
- Headlights dim
- How to mount stillen front lip? Anyone have close up pics??
- .4mm gap spark plug ok??
- cold air intake -help-
- Rear brake help needed!!!!!!!!!
- #4 spark plug
- Question/Concern about shifting and auto trans.
- Leather Restoration
- HOT FEET!! lol
- Checked my car today...wish i hadn't!!!
- 97 SE 0-60 Time
- hyper grounding kit
- Is this statement true??
- anyone around RI/MA paint?
- Engine Problems, Help Please
- Fuel pressure regulator?
- engine sound question
- Can some one photo shop these wheels on my car for me? please
- Has anybody seen this yet??????
- Do I need new calipers??
- output seal on 5spd transmission?
- Warpspeed products: Pros and Cons
- injector project
- Need Shock/Spring Advice Please
- Wiring/Illumination Question for Bi-Xenon H4 Bulbs
- 97 air intake temp sensor in a 96?
- Noise from passenger side...alternator? belt?
- How to remove/replace tail light
- Tokico Illuminas suspension kits installed
- writeup for wiring ipod to bose sterio?
- hmmm my temp gauge is jumping!!!
- Anyone use auto-rx?
- BBK Questions....
- Strut Bar
- COSMO Cold Air Intake
- 300ZX Brakes
- Would these lights match?
- 6 speed
- Help! motor won`t run!!!!
- just come teaser pix of my lights
- Urgent matter regarding rears... Very burning Smell !!
- Flash Relay location
- Brighter Tail lights?
- Take off door panel to replace speakers?
- pulling 0606
- Coolant flushing question
- Carfax My Vin? (please)
- clear turn signals
- LED gauge lighting help
- OBDII Driving Cycle?
- speaker static?!?
- Spring rate questions?
- Wiring Fog lights
- Quick ECU question.... help
- getting rid of raspy sound in exhaust
- looking to replace exhaust system
- Broke Valve Cover Bolt HELP!
- auto tranny?
- what should i ask for in my custom catback setup
- AC blows very cold, then warm
- Overheating ONLY when the A/c is on and..
- Cross generation 5spd Swap
- Automatic to 5 spd conversion ?
- Greddy SP2 owners help plz... pics
- Any experience with SS y-pipes from SS-Autochrome?
- Coilovers vs spring/strut combo
- need some big help
- Need new exhaust setup soon, need opinions
- Cosmo Cold Air Intake?
- suspension info needed?
- 5-speed tranny rebuild
- high pitched whining
- Antenna
- radio ? please help
- H&Rs, Illuminas....Spring Isolators/KYB Mounts and Boots?
- Its been a while ! Post up your engine bay photos !
- Bad Luck
- Anybody Tried Headers and Y Pipe from SSAutochrome?
- poor starting
- rear spoiler brake light
- Projector headlight question.
- Lower crossmember bolt problem
- I'm just curious?
- PNP Switch Info needed please!
- Engine starts horrible...
- brake caliper painting
- Paint Shop?
- hard 1 - 2 shifts on an auto
- Need some help here some weird a## isssues.
- Performance chip?
- vlsd advantage
- 60k miles and the freaking input shaft bearing is shot (5speed owners step in)
- AC problems
- Can a rear caliper freeze up in the retracted position?
- coilover question
- cant close my trunk
- CV joint question and transmission leak
- Belt Tensioner > can't put it back together (pics)
- need some help w/ AC
- Gas Saving question...
- I found a torn hose on my tranny!!
- aftermarket bulbs?
- performance at different temps
- wiper fuse..
- Need Help!! Suspension Question!
- Front Suspension parts
- Something Leaking dont know what yet...
- Changing Alternator (arghhh)
- Math: Why you should use cheap gas - part 2
- how do you adjust or parking brake
- Speed Sensor Problem
- raspy noise coming from exhaust?
- Determining which o2 sensor is bad
- 130$ shipped for 2 bearings and mounts from nissan? Yeah or nay!?
- transmission noise
- AE corners
- Mods that increase mpg
- How to adjust your parking brake
- SUSPENSION springs shocks sruts sways the whole deal
- Car Got Hit
- optimal shift points
- fun drifting possible?
- !?P0136 o2 code?!
- will these rims fit?
- squeek when i turn left..
- battery dead / cant start...what is wrong??
- Gettin car tinted
- EGRC Solenoid valve
- Strange problem, what can it be???
- Changing Fuel Filter
- anyone here black-out their clearance lamps?
- Finally got some wheels!
- Anyone Have A Funtional Hood Scoop????
- headlights
- Ebay Knock Sensor
- Black Max's with Bronze/Gold Rims Step In
- Custom Enterprises Y-Pipe, yes or no?
- Since I had trouble finding the gates belts for a UDP
- help me please help me help me
- IAT Sensor Mod?
- Maxima Muffler sounding.
