- Moving from my trusted '95 GLE to a '97 I30
- How do I remove the A/C condensor?
- How to replace window regulator
- Big CA Smog Check Problem
- Metal Scraping While Starting (Long read)
- iPhone Bluetooth Connection for Bose HU?
- 95/96 fogs
- got my lip kit :)
- Is my MAF sensor done?
- WTB: Black Armrest cover Climate control knob
- How are 99's and 00-01 strut mount bolt patterns different? (regarding stillen FSTB)
- Hit a semi-truck Tire on the free way...scariest thing ever
- A33 Maf on a VQ30DE?
- Question about Front Windshields
- My painted interior is GONE! :D
- Engine swap choices, which is the SMART way to go?
- Changing plugs... unpleasant finding
- www.motorvate.ca?
- emissions due and P0446 code
- changing the fuel filter! ISO advice
- Car starts....sometimes.
- TCM Compatibility - Any differences?
- Ok to use Matic D in the power steering system?
- Total capacity of fluid in the power steering system?
- Brown Dash: The Scar That Won't Heal
- woodgrain steering wheel
- 15th Anniversary
- rotor rust did'nt dissapear after driving all day????
- Oxygen sensor Codes question
- really weird electrical problem
- Info on changing out front wheel bearing
- so my engine blew last week...
- I think im going to get rid of my car. Rust is causing expensive problems w/ exhaust
- Help! LCAs Installed.....Funny Noises!
- Pic Request..5th gen GLE wheels
- Still No air/ No heat
- How many miles till ECU resets?
- No start in cold weather unless push started
- Bad hesitation under power, tachometer drops too...
- tokico blue's warranty claim
- Has anyone tried Blacklight bulbs for......?
- bose speakers not working
- update: redesigned mount for 4th gen installed> pics
- knock knock?? fail?
- Short Throw Shifter
- starter question
- Radiator Fan making very loud grinding noise!
- 1997 Starting issues
- who knew? 469530 ohms
- What are the signs that my alternator is going?
- Hood strut installation instruction
- Need new tires(no one answered in tire forum)
- Car is studdeing really bad at WOT Help!!
- Car does not start anymore!
- Diagram for 0807 Solenoid Valve
- 95 to 99 catback swap.will o2 sensor work?
- Check Engine wount go away!!!
- to buy or not to buy
- Head light shot today..
- HELP!!! MY CAR IS DEAD !!!
- got my CF mirror shells :)
- Maxima Wont Start
- broken headlight mounting screw
- Electrical Shortage
- 4th gen one piece?
- Torque converter housing case, is there a gasket?
- OK, CEL!!!!!!
- had to take my foot off gas before trans shifted 95 auto
- Its been a crazy CEL week.
- Please Read I need help asap!!!!!!!
- Battery Light on!! Break Light on!!
- Do Upper Oil Pan Leak With E.Mounts?
- rear anti-sway bar installation
- 95 Max SE starting problem revisited...
- GAS DEPLEMINSHING
- New CAI Issues
- What year ECU is "B6"? I searched, but....
- Is motorvate down?
- battery drain help please!
- Growling noise passenger front
- gear shift indicator light
- auo TPC on MT throttle body?
- Knock senson bypass question
- !!! help i cant find park in my car !!!
- Replace input shaft bearing
- Car stalls under low rpms
- 95 maxi starting problems.
- Free Serpentine Belt Wear Gauge!!
- rpm tak prob
- Struts, the good, the bad, the cheap...
- How to reset the fatory alarm
- Sister's car is acting strange - Please help
- Update....New Starter installed same problem....need help
- Anti-seize for Spark Plug Threads?
- Need a new muffler... some suggestions?
- no interior lights please hlep
- Where is this tranny leak coming from?
- What other gaskets needed for WP project???
- 95 max mistery harness
- exhaust question
- carbon fiber hood question
- Bad clutch maybe?
- is my car really an SE?
- Pre-Cut Tint
- Tranny leaking fluid
- Code 1605
- Inside trunk dimensions for our maxima?
- Is this proof that my steering rack is bad?
- my car missed 3rd gear??
- Rusted radiator support
- CEL 0801 Part Number
- Output of tsx projectors
- sea foam question
- My car wont start Pt. 2
- jdm tranny install now hesitation during start
- 2008 Stock civic si vs. nissan maxima 4th gen..
- Heating and A/C vent buttons don't work
- Spare Key with chip and automatic starter question
- MAXIMA VS BENZ ?!?!
- SSV4 Suprastick 5.5 gen
- weird brake/axle problem?
- Power steering or rack and pinion?
- Finally----5spd conversion question
- Putting badge on. Need help
- High Flow Exhaust With Good Noise Reduction?
- removing stuck caliper bolts
- how to insert the pass side axle?
- Battery/Brake Lights on at the same time
- replacing cv axle, got questions
- Engine Swap 1999 engine in 1995 Chassis?
- 99 to 95 ECM swap a Success!
- Question about strut replacements
- rebadge mytrunk
- The LED Light Picture Thread -Exterior-
- steering problem - quoted $1600...WTF?
- blinded by the light
- 95 Maxima Doe's Not Start but cranks! HELP! plz
- What's it worth?
- stock air box removal
- idle issue...HELPPPPPPP
- KS...Is it REALLY worth replacing???
- sensor questions
- Can't get the hazard light to illuminate ... ??
- Trunk Finished.
- brake pads ??
- Bank one, Sensor two is..
- M.A.F Sensor Ghost
- Tranny swap....
- Heated seats + Heated Mirrors
- High performance transmission rebuilt kits for our maxima's?
- check this out VQ25DE
- Clock AFR mod
- Header Back Exhaust cost
- transmission?
- KS Resistor Install With Pics
- repair exhaust pipe
- Fuel Pump or Ignition Coils?
- 80 MPH - Car Shakes
- Oxygen Sensor Replacement
- How to test your maf?? help.
- cam sensor? leaking (pic)
- XTREME HIGH EXHAUST !!!
- ALTERNATOR OR BATTERY ?! PLZ HELP FAST !
- relay noise help
- Tein S Tech + AXG __ Any Issues with this combo?
- Zinc primer and rust
- DR Mod & SES light ???'s
- CV Boots
- replacing speakers
- Removing Pillars
- Shift lever problem
- Bose died
- Cooling System Problem???
- Do I have a malfunctioning fuel guage?
- 95/96 clear tails vs. 97-99 clear tails
- Should i buy this??
- 99 Maxima ignition issue: please help!
- Motor slanted
- Car jerks alot, i dont think its the coilpacks
- My clutch sounds like brake moan! Like a dragging caliper.
- Creaky coilovers. Help?
- My Maxima gets over 31 mpg avg. Should this be possible?
- HYPER GROUND WIRE KIT ?!?!
- p1320 Ignition signal circuit HELP!? '95 Maxipad
- ???Throttle Body Cleaned....Now Higher Idle RPM 600 to 900
- 00vi users who have passed California Smog?
- Opinio on new ball joints and sway links
- P0135 p0155 p0141 p0161 grrr
- rear brakes hanging up
- Is my alternator bad?
- Motor or something is shaking while gunning it or tapping gas pedal. Can't Figure out
- E-brake sensor
- Need some insight please...
- retros from depoautolights?
- Gauge Lighting
- how much C4?
- rotor scrape sound
- clunking noise/bad transmission mount?
- Decent Seat Covers?
- My '97 Stick Maxima won't go into 1st or 2nd gear
- Car will not even crank after tranny reinstallation
- Advice please .......
- Immobilzer went out after resetting ECU - Wonderful
- Clutch problems
- ECM harness/connector location on a 97 max
- Vacuum in Absolute Pressure Sensor line?
- ecu installation and weird idle
- Keyless Entry Remotes
- HID Experts Step In
- Testing Digital Climate control/and Understanding the Codes
- Need Best Deal on Starter....help
- Had a Bad Day, need some advice...
- noise in neutral
- Exhaust smell inside the car?
- Gauge light issue
- HID's
- CPS o-ring leak + bad noise
- My hazard lights and the defroster lights don't work
- Bringing one back from the dead???
- VQ30 Gurus I Need Help
- intake sensor question?
- I need help with this problem
- bad fuel injector?
- Alternator causing problems ?!?!
- A/T service
- I was on overhaulin! But not really
- Voluntary Service Campaign: 1996 Maxima MIL issues
- bad cv joint?? only about 3,000 miles?
- Alarm Malfunction????
- Loose wheel lug
- What are some cheap fixes for our 4th gens?
- should i make these??
- Warm air when AC on. WUTS WRONG?!
- replacing differential seal
- 4th gen maxima for 600$ ?!??!?!
- Changing Wheel size from 15` to 16` ?
- Red Lion Racing Traction Rods
- New Spark Plugs Installed
- Need your instructions on removing CV axles, picture attached
- Opinions needed! what would you guys pay for these headlights?
- 99 Fed spec 00vi swap - Questions on newly discovered coolant hose routes/EVAP *PICS
- how to tell whether the engine or tranny was replaced?
- 99 to 95 engine harness swap
- Evap System - bypassing/removing vacuum cut valve
- shifting without clutching with car off
- 95 max with Bose, amp question
- Brake Light On Intermittently
- 97-99 Red/Clear templates
- Random hard starts.....
- Window base screws... part number?
